Picked up a Pennyan Cartopper LXH52433 (not positive about the first two letters).
The ribs and strakes are in good shape outside of a single 1 inch gash through the planking 6-8 inches above the waterline. The canvas is in bad shape. It has a tare repaired (light green line in hull photo) with fiberglass years ago but near the keel (shadow area) there is a big ripped section (hand photo). The section of canas next to the right bilge keel is seperated from the canvas going under the bilge keel and can be lifted to expose the strakes. Given that I would guess the canvas runs on the keel and both bilge keels are very weak. There are also sections along the bottom of the transom that have exposed canvas and wood sections so would leak.
Would it be possible to put on a quick repair to get some use out of it this summer? The thought was to lay some fiberglass on after stripping and sanding or apply something like Xynole. The keel and bilge keels would have to be removed and large layer of something put on to cover the whole bottom about to where it starts to curve up i.e. the flat section of the bottom.
I don't know what the white paint is and the canvas cover origin so the fill the original aluminum stuff Pennyan used. It's brittle in some areas due to being in the sun.
What can be done if anything to put on an easy patch to get some use out of it before a later restore? Would anything even stick to the old canvas?
