Strickland Canoe
Paul G
Hi All
I have recently required a Strickland strip canoe but the brass plate for the flag hole is missing any thoughts as to there I can source one from.
PaulG
Any pics of the boat and decks, Paul ? How do you know it had a brass plate ? Does it have the floor board(s) ? Are there Strickland plates at the thwarts ? Dave
I once used a brass tank connector to solve a flag socket problem. It will depend on what size you want and how authentic you want to be. I thought it was better than leaving a ragged hole.
I want it to be as authentic as possible Sam.It currently has a decorative wooden piece attached covering the flag hole.
It has the name plates on the side.If I cannot source an original plate any images and size would be helpful to be able to get one made.
Best I can do tonight. I can take some measurements tomorrow. Does your canoe have a number, under the thwarts, for instance?
Charlie.
That might be the easiest. I think they were spun brass and quite fragile. Mine has been 'improved' by being filled with lead solder.
Dimensions : ID 1 5/8", OD 2 1/2", height 1/4" (41, 64, 6.5mm).
Peut-être possible par formation en une seule pièce à partir d'un tube...
https://www.google.com/search?q=flu...mh0bWwSEU1hY2hpbmUtb3V0aWwuY29tGu8BZGF0YTppbW FnZS93ZWJwO2Jhc2U2NCxVa2xHUnBvQUFBQlhSVUpRVmxBNElJNEFBQURRQkFDZEFTb2dBQ0FBUHRFdXRGb29JYWdvR0FFQUdnbHNBS3dBYUYvQ3VjNVEvVGVJU0s5T3FkTzI2M283ekFEKzdUU1VlSDU0NGNxQU40cGpVWlk3LzZhUi8vVFNQLzZhUnB6YVBkTi9GM1JyaTVzZFEwWmNlL0U2ZkZyL3Y2SVJ TWXRGMGlkakxLSjh0RmZsdWFqY041ZkVCU2dTajN3c1lNVWN1WEFhUjM2N3Fad05hNy9iL05OVk9HQUEgATgBCr4CCrsC0tnb0g-0Ago44oaSIFJlcG91c3NhZ2UtZmx1b3RvdXJuYWdlIDogZXhwbGljYXRpb24gZGVzIHByb2PDqWTDqXMST2h0dHBzOi8vd3d3Lm1hY2hpbmUtb3V0aWwuY29tL2FjdHVh bGl0ZXMvdDYzL2E1NjE2LXJlcG91c3NhZ2UtZmx1b3RvdXJuYWdlLmh0bWwapgFMZSByZXBvdXNzYWdlIGVzdCB1biBmb3JtYWdlIHByb2dyZXNzaWYgZW4gcGx1c2lldXJzIHBhc3NlcyBxdWkgInBsYXF1ZW50IiBsYSBwacOoY2Ugc3VyIHVuIG1hbmRyaW4gZW4gcm90YXRpb24uIExlIG3DqXRhbCBzd WJpdCBkZXMgdHJhY3Rpb25zLWNvbXByZXNzaW9ucyBtYWlzIGwgLi4uCvsJCvgJwtnb0g__AqoBEFdFQl9SRVNVTFRfSU5ORVKyAVoKT2h0dHBzOi8vd3d3Lm1hY2hpbmUtb3V0aWwuY29tL2FjdHVhbGl0ZXMvdDYzL2E1NjE2LXJlcG91c3NhZ2UtZmx1b3RvdXJuYWdlLmh0bWwSA09GRhgAIADiAYsCCr wBTGUgPGI-cmVwb3Vzc2FnZTwvYj4gZXN0IHVuIGZvcm1hZ2UgcHJvZ3Jlc3NpZiBlbiBwbHVzaWV1cnMgcGFzc2VzIHF1aSAmcXVvdDtwbGFxdWVu dCZxdW90OyBsYSBwacOoY2Ugc3VyIHVuIG1hbmRyaW4gZW4gcm90YXRpb24uIExlIG3DqXRhbCBzdWJpdCBkZXMgdHJhY3Rpb25zLWNvbXByZXNzaW9 ucyBtYWlzIGwmbmJzcDsuLi4SRuKGkiA8Yj5SZXBvdXNzYWdlPC9iPi08Yj5mbHVvdG91cm5hZ2U8L2I-IDogZXhwbGljYXRpb24gZGVzIHByb2PDqWTDqXMYACAToAFiwAEB4AEB6AEBCswGCskGytnb0g_CBhKaBiKXBi9zZWFyY2gvYWJvdXQtdGhpcy1yZXN1bHQ_b3JpZ2luPXd3dy5nb29nbGUuY29t JnJlcT1DazlvZEhSd2N6b3ZMM2QzZHk1dFlXTm9hVzVsTFc5MWRHbHNMbU52YlM5aFkzUjFZV3hwZEdWekwzUTJNeTloTlRZeE5pMXlaWEJ2ZFhOellXZGxMV1pzZFc5MGIzVnlibUZuWlM1b2RHMXNFZ1FhQWdnQUdyc0RFZ0FhQUNJQUtnQXlCZ2dCRWdKbWNqb0FRZ1FJQVJBRVNnQmFBSElBZWdDQ1FKY-A4
Which I think means metalspinning on a former is possible. Is the mast ring on mine standard on others?
Fluotournage repoussage est possible, c'est ca?
Its the french words , so find a turner for that and ask if is it possible but he must need the template form , or a turner who can made it from solid brass as say Michael , or the template for the other turner :rolleyes:
old curtain bras ring is also a possibility
I am familiar with metal spinning but not sure that would be the method.
Turning from solid brass would be best option but a design.
They are for sure plumbing fittings as Michael has noted, had a laugh at the gym where there are multiple shower heads and each one had the same fitting, albeit a larger diameter and chromed rather than nickled like back when they were made originally. I have a few brass that have been turned, to match the older ones. Would be easy enough to make a larger diameter mast if one could locate a few, and dont forget the cup on the stem for the mast base.
Will take a closer look at the hole size tomorrow.
I have been looking at plumbing fittings and door furniture.
