i've been working through the winter on my 1936 HW 16', and am finally getting towards the end. Rib tops are scarfed, deck plates are ready to go, seats and thwarts are refinished, and the doug fir inwales are bent and varnished and ready for install.
NOW WHAT?
not really sure how to proceed on the next step:
- the boat had some pretty rotted stems (i scarfed on new tips), it was missing one deck plate and the remaining one wasn't in the best shape to begin with, and the inwale ends were rotted off, so i can't see the nuances of getting a nice tight joint between the deck plate and the inwale.
i'm so close to varnish and canvassing, i don't want my exctiment to cloud my judgement and break something!
my questions are many, but i'll limit them to:
- are you putting bedding compound on the joint (like it says in stelmok's book?), and what's the benefit of that?
- are the inwales evenly tapered, or do they accelerate towards the ends?
- is everything square, or do i need to bevel either plate or inwale edges, or both?
- do i secure one rail on the boat to the end, then the plate, then the other rail, or do i do both inwales up to the last 2', then get a tight fit on the deck plate, then attach to the ribs?
- how much clamp pressure do i need to put on the inwales to bend to the deck plates, or should the joint be flush without clamp pressure?
thanks for your input!
ryan in DC
NOW WHAT?
ryan in DC
