Hi, Restoring 1941 OT 18' Guide. Not sure how the stem, inner & outer gunnels and deck plates are tied together as they are rotted apart. Need to replace 4" of stem on bow and stern. Anyone have pictures or a drawing that would help. Thanks
Rebuilding tips of canoes seems necessary so often simply because otherwise well meaning people find it easy to set a canoe on the ground, overturn it, and leave it there. True, the seats and ribs/interior are protected, and dry for when next you use it. But leaving the tips on the ground means premature wood rot. We see it so often.
I am editing this to put in what I feel is a VERY VERY important point. You need to know what the original stem looked like both side and top views. I made a template using a 17 ft OT HW. I have been back to the other canoe a dozen times and more. I cannot...
Vince, I read the advice of Bruce Whittington about creating a stem bracket, in the thread mentioned above by Benson.
My version of the bracket is at https://forums.wcha.org/threads/stem-joint-to-deck-and-inwales.19047/
I needed a spacer because my decks were thinner than my inwales. I hope you can make that out in the pictures.
