Brian J Knudsen
I have a 1923 17' Otca. I plan to replace the inwales, unless I'm convinced otherwise. The tips of the inwales on both ends are gone. They are cracked and broken in various places on both sides and the canoe looks misshaped.
I have read some great threads about how to steam and clamp the new inrails/inwales to the old inwales. I have a few questions though that I have not found answers to.
I put a caliper up to the rail at the center of the canoe and there is a bevel as I expected. Does anyone know what is the angle of the bevel?
I also put the caliper up next to the inwale where the inwale had pulled away from the deck and the caliper sits flush on both sides of the inwale, so I don't believe there is a bevel next to the decks. Do you have suggestions on how to cut the correct bevel into the inrail?
Lastly, for now, when should I replace the inwale? The canoe needs to have stems repaired, tips of the decks repaired, ribs replaced, and planking. Am I correct in believing that the rails should happen first?
Thank you,
Brian
Thank you,
Brian
