Old Town H.W. 17' built in 1946
PHenry1969
I am working on restoring an Old Town HW from 1946 with sail rig. I have the original recite for the canoe based on serial number. I am trying to determine if the outer stems were canvas covered or exposed in this model of canoe and if they were covered in canvas how was the transition from canvas covered stem to uncovered keel was accomplished since the stems are higher than the bottom of the canoe where they meet the keel. Can anyone share pictures of their Old Town HW stem to keel junction and stems either shown exposed or un exposed. I would also like to determine house the metal stem protection strip interacted with the mounting hardware for the rudder. I have a rudder and the metal stem but the photos I have of the boat at the start of restoration shows a wide flat exterior stem with mounted angle bracket shaped rudder gudgeons and no metal protection strip.
In my experience, outside stems are never covered with canvas. Most certainly not on an Old Town, and never on any other canoes I have owned. White canoes were built with a formed copper strip that covered the stems, but that is unique to White canoes.....
The inside stems are covered with the seam where the canvas is closed on the bow and stern, then covered by the outside stems. Outside stems do receive stem bands. The gudgeons are installed over the stem bands. I'm not a sailor and no longer own a sailing canoe, but that is my recollection. Someone else who sails will undoubtedly provide the correct answer.
I agree with MGC and the pictures below show the outside stem to keel junctions, bang plates, and gudegons on two Otca models from 1936 and 1958. The canvas goes under the outside stems and keel, the stem bands go over both, and the gudgeons go on top of everything as MGC mentioned. This would have been done the same way on your HW model in the 1940s. The link below has more details about these canoes. Let me know if this doesn't answer your question.
Hi PHenry. MGC and Benson have explained most everything in their answers, so I'll just add a few details. Outside stems, as shown in Benson's photos and as you suggested, are continuous with the keel. Therefore there is no way to canvas over outside stems (and keel). The canvas would bridge an increasingly large triangle of air as you go down the stem and to the keel. Cedar-canvas canoes are built - ribs and planking and gunwales (inwales) - and then canvased before the keel and sometimes outside stems are added. The outside stems add a measure of protection to the canoe's ends, they are decorative, and they effectively carry the keel all the way around the ends of the canoe. In any case, are never and cannot be canvassed.
The "metal stem protection strip" on most cedar-canvas canoes is called a stem band. Because the stem mates smoothly with the outside stems as shown in Benson's photos (look for the angled junctions), the stem band simply flows from the stem onto the keel uninterrupted. On canoes that don't have outside stems, the keel ends are long tapers down to nothing so the stem bands can transition from the filled canvas onto the keel.
The canoe-side rudder-mounting hardware are a pair of gudgeons (as you know). The corresponding parts on the rudder are called pintles. It's hard to see in the photos above, but there are two sets of mounting holes on each gudgeon. After the keel, outside stems and stem bands are mounted on a cedar-canvas canoe, for each gudgeon a pair of holes is drilled laterally through the outside stems and then the gudgeons are mounted with copper or brass rod that is cut just slightly long and peened over to hold the gudgeon in place. On canoes without outside stems, the process is the same except the mounting holes are drilled through the canvas and inside stem.
