It's Official - my '51 OTCA project
OP
OP
mmmalmberg
mmmalmberg
Re-reading my notes earlier in the thread, I got two full coats on using 4/5 of a gallon of the filler. The first coat was tinted darker so I could see when I was sanding through the second coat. And then the remainder of the filler I spread with a flexible stainless steel spreader, to maximize filling in the low areas.
Dave Osborn
LIFE MEMBER
I had one do something similar once.
I removed the canvas to find that the varnish between the planks erupted when the planks swelled causing the bump along the plank seam.
I scraped out the excess varnish between the planks and recanvassed it. No problem after that.
I no longer attempt to fill plank seams with varnish and always varnish before canvassing.
OP
OP
mmmalmberg
mmmalmberg
That all sounds about right. I'm sure I had plenty of varnish going between the planks and onto the canvas. But how I hate the thought of removing the keel and stem bands and outer stems and outwales, and canvasing again! Well I no longer have a place to do it for a while so I guess I can just take my time getting used to the idea:)
dtdcanoes
M&M .... this could be a half full cup. You could find another canoe because this one needs a c orrection that will take some time and doing, and you don't want to miss out on another season. I think maybe you should go on the hunt sooner than later, and yes, it does seem a bit vicarious on my part. Sooo ?
Dave
OP
OP
mmmalmberg
mmmalmberg
Dave
I'm also thinking maybe just use it and let the canvas do its funky thing, until I can re-do it. Unless or until it causes the canvas to crack it can't really hurt anything, right? BTW it seems to have dried down to pretty nearly flat, hard to believe...
OP
OP
mmmalmberg
mmmalmberg
I know the probable answer but is there any possibility, once a canvas has been filled and painted, of somehow carefully removing it and putting it back on? Like if I could preserve its form carefully, could I work on the hull and then reattach the canvas?
Other than that, I may need someone up here in WA, while I'm up here, to re-do the canvas for me as I no longer have a shop and I don't think I have the time, will nor inner strength to do this again...
dtdcanoes
Oh, yes that can be done and I know a builder who while gone now has done it more than once. I never talked with him much regarding the technique but given that you have canvased to finish before I should think you could reflect a good deal on careful handling, supporting etc. to keep it sound without any cracking, creasing, and it would go back on very well with a good level of satisfaction.
I bet there are others here who can advise. It is certainly worth a try as you have just time to loose . I should think the max patience should be used at the stems as you will not have much to waste if you
go too fast and loose even 1/2 inch. Take pics. Others are interested as your plight is not that rare.
Above all, have some fun with lots of pics.
