ID Help
SteveDetwiler
Would like to identify unknown manufacturer. Serial #4580 18. Original deck photo attached.
If your canoe is an Old Town (as the deck could indicated) the Old Town canoe with serial number 4580 is shown as 16 feet long, CS (common sense) grade, HW model with western cedar planking, spruce gunwales, ash decks, seats, and thwarts. The date stamps on the build record are not readable. The original exterior paint color was dark green. It was shipped to H.B.Crosier in Jackson, Michigan on May 21, 1906. A scan of this build record can be found by following the link behind the thumbnail image attached below.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. The indicated length is different than indicated by the full number you provided.
If that is the case, photographs of the deck, side profile, seats, and other details would be helpful in identifying the canoe. Does the canoe have the typical OT diamond head bolts?
Feel free to reply here if you have any other questions. Feel free to reply here if you have any other questions.
Greg
Thanks Greg. I suspect it is another manufacturer - no OT decal, no diamond head bolts. It measures 18' as indicated in serial #'s. I'll have to get it outside for more photos (stored in a crawl space under a porch now).
Steve.....don't rule out OT due to the diamond heads or decals. If it is an older canoe then it would not have diamond head bolts. OT started using those in the early 20's (?).
And decals often don't often survive refinishing.
The deck does look OT.......but to contrast here is a picture of a 1906 deck. The curves are not the same.
Try the same number for Carleton.
There are no Carleton records for this serial number which implies that this number was issued before Old Town purchased Carleton in 1910. My guess is that there are some hidden digits. Please review the tips described at http://forums.wcha.org/showthread.php?791 to see if you can find them and post some pictures of the stems from each end. Thanks,
MGC,
Is that the original deck in your 1906? It looks a bit "newer", ie closer to the late deck style.
I have a 1928 HW, SN 96206, that has decks that look exactly like the one Steve shows, except they are ash.
It does have the diamond bolts though.
Well, I guess the '28 isn't exact.
Here are images of the 28 and 50, both 17' HW's.
