ID Help Sailing Canoe
SteveDetwiler
Need help identifying manufacturer of 18' sailing canoe - serial #05592. All original including lee boards. Deck photo attached.
Looks like you have a small fleet on your hands. But again, the OT serial number doesn’t seem to fit your canoe.
The Old Town canoe with serial number 05592 is shown as 16 feet long, CS (common sense) grade, CR (Charles River) model with spruce gunwales and rail, ash decks, seats, and thwarts, and fitted with a keel. The canoe was built in 1907, being finsihed on March 21, 1907/. The original exterior paint color was dark green. It was shipped to Hartford, CT on August 26, 1907. A scan of this build record can be found by following the link behind the thumbnail image attached below.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. The indicated length is different than the length you provide. As built, 05592 was not fitted out as a sailing canoe, but sailing gear was often not provided at the factory, but by the dealer or other aftermarket supplier.
If that is the case, photographs of the deck, side profile, seats, and other details would be helpful in identifying the canoe. Does the canoe have the typical OT diamond head bolts?
Feel free to reply here if you have any other questions. Feel free to reply here if you have any other questions.
Greg
Canoe 15592 is a 17 foot AA HW with long mahogany decks, double mahogany gunwales, a keel, floor rack, and outside stems. No indication of sailing gear. Shipped to Middleton, MA on March 21, 1911 -- well before diamond head bolts, but still a foot shorter than 18 feet. Indeed, all the numbers in the series *5592 are shorter than 18' --
25592 - 17'
3 16
4 15'
5 17'
6 17'
7 16'
8 16'
9 16'
Have you checked the numbers at both ends?
Greg
Greg
