pasteljoe
hello all,
I'm actually building an Atkinson traveller canoë, and I use ash to make the ribs, spruce for the planking. As the ash is a hard wood, the tickness is reduced to 4mm (3/16").
After steamed it an applied all on the form, pushed all the ribs on the form by a solid piece of wood, I let it dry for several days. And the planking followed.
After I removed the canoe from the form, I checked the straight line and measures. And I realized that the ribs of the bottom at the middle was rebound of approx 2cm (13/16") . They didn't retain the shape of the form, which means that the sheer line of the canoe is altered.
I built two canoes, and the two have the same problem.. the first was the worst, I finally achieved a kind of "cree canoe", like a banana... Unusable on calm waters..
here's a little illustration of the first canoe :
Even if on my second canoe, the 13/16" move is not significant, I would like to be able to preserve the original shape of the design...
Has anyone ever encountered this problem before? is the type of wood thats poses a problem ? it is the same with the cedar ribs and you have to compensate with the shape of the form ?
Thanks you all !
ps : a littles pics of the second project :
Thanks you all !
