Looking for images L.A. Picard Square Stern Canoe (circa 1976)
brandon_deyoung
I recently rescued a 16 foot 1976 L.A. Picard square stern Canoe. It appears to have cedar ribs and a fiberglass hull. I'm planning on restoring it and am looking for images of what it looked like new. I'm mostly interested in the transom, which is very rotten and has had several repairs.
Welcome and congratulations, the available information may be limited. The old Picard catalog at https://woodencanoemuseum.org/manufacturer-catalog/picard-brothers and the classified archive at https://wcha.org/classified-archive/Great-Canadian.html don't show a square stern. The Great Canadian catalogs at https://exhibits.lib.usu.edu/exhibits/show/outdoorcatalogs_g-n/company_gallery/greatcanadiancanoe only show the covers. You may want to contact the Utah State University Library directly to see if they can send you scans showing the interior pages. Please let me know if you find a better resource for this quest. Good luck,
Take a few pictures of the existing inner framework, likely its as most are assembled, not much new under the sun. If its an interior framework attached to a very wide final rib, its quite easy. No outboard framing is there, making it even easier. Can put up some pics of usual framing after you post, cheers
Here's a few pics of the transom. I'm sure the glass added to the outer edges was done as a repair as the person who did it didn't seem to own any sandpaper. I'm not sure about the 3 Steel L-Brackets on the interior. I suspect they were added as a repair, but the fact that some are through-bolted makes me wonder. The transom is about 1.25" thick
Ah, okay. no inner frame, just nailed through the furthest end of the planking and rib, and knees to hold it. take it all apart being careful with the last piece of rib, and whoever glassed it relied on the overlap as well. if it were mine i would make the transom knee and the gunwhale knee out of hardwood, nicer looking than the steel brackets. canvas or fiberglass will need to be brought around to the transom to wateproof the joint where the planks attach since there was no inner bracket. More usually the covering will wrap around then the transom board will go on last, but its not a problem to do it that way. will be a nice canoe when its done
this is a better way to build, but that way will work just fine as well. the builder didnt bother with an inner frame but between the brackets , plank fastening and glass its all good
Constructoin details are always interesting, and there are usually multiple good ways to do things. That said, why is the above method "better"? It appears that the same amount of wood is in contact with the hull whether the contact is made directly by the transom or rather by an inner frame with to which the transom is mounted outside the frame. An inner frame should provide mo more strength (at the junction with the hull) than the transom itself, except that there is simply more wood with the transom and the frame. T
he wooden brackets and the metal brackets may provide similar strength. The metal is probably inherently stronger but the larger wooden brackets spread the load of forces over a larger area of the gunwales and floor (and I just like the wooden brackets - they are traditional and look nice).
Finally, grain orientation probably matters too. in solid wood transoms, horizontal grain will stand up better to the forces from a motor than would vertical grain.
Both methods for transom mounting probably work just fine.
yeah, I had the same thought about making hardwood knees. I've got some half-inch okume. I'm thinking I'll epoxy & glass two pieces together for the new transom.
That said, why is the above method "better"? Mostly as there is no way to capture a traditional canvas covering , so they shortcut the whole thing with plywood and glassed around it rather than frame it
hi Benson, Thanks for the tips. I asked Utah State University Library to digitize the rest of the 1975 Catalogue and they did. It doesn't have what I was looking for, but its still interesting. Attaching here in case anyone else is looking.
Ah, okay. Yeah, that broken down transom and poor glass job leave something to be desired. By "captured" I'm guessing that the canvas would be attached to the inner frame before the transom is bolted on. Others attach the canvas on the rear of the already-mounted transom and then cover the canvas with a bit of framing.
At least some manufacturers didn't use any kind of frame. Instead they neatly attached the canvas around the perimeter of the stern. Here's one example from Penn Yan (and I think some of our celebrated modern builders have built square sterns much the same) in which the transom is mounted, there is no frame inside or outside, and canvas at the stern is doubled and attached around the perimeter. Not saying this is better or worse, but it works. I've had multiple boats built this way that still had their original coverings after some 80 years, still intact at the transom even if damaged elsewhere. With a little care and fitness, the end result is very neat and long lasting. Different strokes...
