Strickland Canoe
Paul G
Hi All
I have recently required a Strickland strip canoe but the brass plate for the flag hole is missing any thoughts as to there I can source one from.
PaulG
Any pics of the boat and decks, Paul ? How do you know it had a brass plate ? Does it have the floor board(s) ? Are there Strickland plates at the thwarts ? Dave
I once used a brass tank connector to solve a flag socket problem. It will depend on what size you want and how authentic you want to be. I thought it was better than leaving a ragged hole.
I want it to be as authentic as possible Sam.It currently has a decorative wooden piece attached covering the flag hole.
It has the name plates on the side.If I cannot source an original plate any images and size would be helpful to be able to get one made.
Best I can do tonight. I can take some measurements tomorrow. Does your canoe have a number, under the thwarts, for instance?
Charlie.
I've always thought these mast rings were plumbing fittings from way back when, likely used where pipes passed through walls. I've looked and looked but haven't found a source today, so long ago I had a few turned from solid brass for my needs.
That might be the easiest. I think they were spun brass and quite fragile. Mine has been 'improved' by being filled with lead solder.
Dimensions : ID 1 5/8", OD 2 1/2", height 1/4" (41, 64, 6.5mm).
Peut-être possible par formation en une seule pièce à partir d'un tube...
https://www.google.com/search?q=flu...mh0bWwSEU1hY2hpbmUtb3V0aWwuY29tGu8BZGF0YTppbW FnZS93ZWJwO2Jhc2U2NCxVa2xHUnBvQUFBQlhSVUpRVmxBNElJNEFBQURRQkFDZEFTb2dBQ0FBUHRFdXRGb29JYWdvR0FFQUdnbHNBS3dBYUYvQ3VjNVEvVGVJU0s5T3FkTzI2M283ekFEKzdUU1VlSDU0NGNxQU40cGpVWlk3LzZhUi8vVFNQLzZhUnB6YVBkTi9GM1JyaTVzZFEwWmNlL0U2ZkZyL3Y2SVJ TWXRGMGlkakxLSjh0RmZsdWFqY041ZkVCU2dTajN3c1lNVWN1WEFhUjM2N3Fad05hNy9iL05OVk9HQUEgATgBCr4CCrsC0tnb0g-0Ago44oaSIFJlcG91c3NhZ2UtZmx1b3RvdXJuYWdlIDogZXhwbGljYXRpb24gZGVzIHByb2PDqWTDqXMST2h0dHBzOi8vd3d3Lm1hY2hpbmUtb3V0aWwuY29tL2FjdHVh bGl0ZXMvdDYzL2E1NjE2LXJlcG91c3NhZ2UtZmx1b3RvdXJuYWdlLmh0bWwapgFMZSByZXBvdXNzYWdlIGVzdCB1biBmb3JtYWdlIHByb2dyZXNzaWYgZW4gcGx1c2lldXJzIHBhc3NlcyBxdWkgInBsYXF1ZW50IiBsYSBwacOoY2Ugc3VyIHVuIG1hbmRyaW4gZW4gcm90YXRpb24uIExlIG3DqXRhbCBzd WJpdCBkZXMgdHJhY3Rpb25zLWNvbXByZXNzaW9ucyBtYWlzIGwgLi4uCvsJCvgJwtnb0g__AqoBEFdFQl9SRVNVTFRfSU5ORVKyAVoKT2h0dHBzOi8vd3d3Lm1hY2hpbmUtb3V0aWwuY29tL2FjdHVhbGl0ZXMvdDYzL2E1NjE2LXJlcG91c3NhZ2UtZmx1b3RvdXJuYWdlLmh0bWwSA09GRhgAIADiAYsCCr wBTGUgPGI-cmVwb3Vzc2FnZTwvYj4gZXN0IHVuIGZvcm1hZ2UgcHJvZ3Jlc3NpZiBlbiBwbHVzaWV1cnMgcGFzc2VzIHF1aSAmcXVvdDtwbGFxdWVu dCZxdW90OyBsYSBwacOoY2Ugc3VyIHVuIG1hbmRyaW4gZW4gcm90YXRpb24uIExlIG3DqXRhbCBzdWJpdCBkZXMgdHJhY3Rpb25zLWNvbXByZXNzaW9 ucyBtYWlzIGwmbmJzcDsuLi4SRuKGkiA8Yj5SZXBvdXNzYWdlPC9iPi08Yj5mbHVvdG91cm5hZ2U8L2I-IDogZXhwbGljYXRpb24gZGVzIHByb2PDqWTDqXMYACAToAFiwAEB4AEB6AEBCswGCskGytnb0g_CBhKaBiKXBi9zZWFyY2gvYWJvdXQtdGhpcy1yZXN1bHQ_b3JpZ2luPXd3dy5nb29nbGUuY29t JnJlcT1DazlvZEhSd2N6b3ZMM2QzZHk1dFlXTm9hVzVsTFc5MWRHbHNMbU52YlM5aFkzUjFZV3hwZEdWekwzUTJNeTloTlRZeE5pMXlaWEJ2ZFhOellXZGxMV1pzZFc5MGIzVnlibUZuWlM1b2RHMXNFZ1FhQWdnQUdyc0RFZ0FhQUNJQUtnQXlCZ2dCRWdKbWNqb0FRZ1FJQVJBRVNnQmFBSElBZWdDQ1FKY-A4
Which I think means metalspinning on a former is possible. Is the mast ring on mine standard on others?
Fluotournage repoussage est possible, c'est ca?
Charlie.
Cannot see any numbers just the 6 brass name plates.
Its the french words , so find a turner for that and ask if is it possible but he must need the template form , or a turner who can made it from solid brass as say Michael , or the template for the other turner :rolleyes:
old curtain bras ring is also a possibility
I am familiar with metal spinning but not sure that would be the method.
Turning from solid brass would be best option but a design.
Away over the weekend but I'll get pictures of the Peterborough version on Monday
They are for sure plumbing fittings as Michael has noted, had a laugh at the gym where there are multiple shower heads and each one had the same fitting, albeit a larger diameter and chromed rather than nickled like back when they were made originally. I have a few brass that have been turned, to match the older ones. Would be easy enough to make a larger diameter mast if one could locate a few, and dont forget the cup on the stem for the mast base.
Will take a closer look at the hole size tomorrow.
I have been looking at plumbing fittings and door furniture.
