patrick corry
solo canoeist
I'm about to steam bend new Ash inwale stock for a Chestnut I'm restoring. I plan to steam and temporarily clamp them to & under the existing inwales (with excess material poking through the currently open stems) until they have assumed their appropriate shape.
My question is this; does the grain orientation matter? Both pieces of bending stock have largely vertical grain. Logic suggests that it may bend more successfully if the grain is vertical, so that flat grain is bending in the width of the canoe rather than bending up at the stems. Presumably flat grain will accept greater deflection without problems. There is clearly more curve athwartship (17" from center), than the sweep of the sheer (about 9" maximum curve).
Final dimensions will be 1" tall, 9/16" at top, 11/16" at bottom (8 degree bevel on the face against the ribs).
Am I (as usual) overthinking this?
