Working on a Chestnut canoe I picked up at the assembly. I was thinking I would scarf in the gunwale repairs to replace the badly done prier repairs. (In-wales spliced with a 45 deg. cut that has separated)
However after scraping off some of the cloudy varnish i found the gunwales are oak. Is normal or was this a original option for a Chestnut? I can find quarter saw oak easily at the lumber yard because its used as stain grade house trim. The more I think about it I would like to use a lighter wood, especially if the oak is not original. Also the one out-wale is wavy and fastened with deck screws. So I wouldn't mind replacing it completely anyways . Can I use construction grade spruce scarfed together? There is very little rise is the shear at the stems so I'm not to worried about bending the ends with kiln dried wood. Or is there a relatively local to south east PA/ cheap shipping option for better material.
The canoe is sound and I won't be doing any rib or planking work just looking to make functional improvement before re-canvasing and varnishing. I'm looking at the project as repair and paddle, not a restoration. As I'm planning to use this as my every week bum around boat not a show piece. I just don't want to do harm in the name of lazy. Or save $20 in the name of cheap.
