Serial # 150275
rbartow
Greetings,
A neighbor has the following Serial numbered canoe: 150275. Any information would be appreciated. Looks very .
Thanks for the assistance,
Rick Bartow
Raquette Lake, NY
The Old Town canoe with serial number 150275 is a 16 foot long, CS (Common Sense) grade, Yankee model with white Maine cedar planking, open spruce gunwales and a keel. It was built between February and May, 1948. The original exterior paint color was dark green. It was shipped on June 11th, 1948 to Rochester, New York. A scan of this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to join.
