Dan Lindberg
Ex Wood Hoarder
Hi Bob,
Mike,
The baseline, (or strongback line) is just a reference line included on the drawings to show at what height the strongback is.
It can be anything/anywhere as long as the canoe shear misses the strongback. Moores likes to have it high (farther from the bottom of the canoe) so that any length canoe can be built above the strongback (and the strongback built lower to account for this).
But it must be at the same relative location on each station and end form, otherwise you'll get a "crooked" canoe.
I'm not sure what your fix will be, but, be sure you understand what's happening before you cut wood. Adding (screw/nail/glue) or removing pieces from the stations doesn't hurt anything, as long as everything is lined up correctly.
Ideally, you will have a verticle line and a horizontal line at the reference point on each station, along with the shear line locations. When lining up the
stations, you should be able to site down the "canoe" and see these lines all in alignment.
Mike,
