Michael, definitely looking forward to seeing your pictures!
Got it in the shop last night and the boat has had a lot of bandaids.....This has the 3 bad repairs you always only hope for one of in a wooden boat: Bondo, Fiberglass, and Foam. Thought the foam in the ends was for flotation, nope. Theres only about 6 inches of stem in the bow and stern. Actually the foam and fiberglass has probably helped enough to keep the shape that I can actually trace the lines for the new stems...THere is only one broken frame from what I have found so far...
Question: Were the stems in these steam bend or sawn? Cedar, white oak, ash?
So the decks appear to actually have(had) standard length white guide style decks underneath them and the longer ones were just an add on. I know the long decks are somewhat rare from what I'm hearing...but I do prfer the standard ones in terms of packing and space. Would people shoot me if I went to standard mahogany decks on this?
Here is my thought on structural order of work on the boat:
-MEasure, measure measure. Pattern and take note of everythning I could possibly need to from the outside.
-REmove decks, foam, etc.....
-Remove gunwhales
-Remove---errr...fiberglass
-re-assess
-Stems
-inwale scarfs
-Plank ends(guessing)
-any bad planking
-replaced cracked rib
Here is a link to an album with a bunch more pics--having a hard time getting them all to upload on here. Guessing I'm not gong to find a serial number anywhere on the non existant stems....
https://drive.google.com/drive/folders/0B5QGsk-tgnyddVAxeV9vOWo2Zlk?usp=sharing
Thanks for any and all input!!!
