Atkinson Traveler build; inwales & ribs
patrick corry
solo canoeist
Apologies first; I've posted about this project in several places and now have no coherent overall build post.
After waiting a long time to acquire 18' stock for inwales (Sitka spruce), I'm finally getting this project going. From my reading I gather it's common to simply dry-bend the inwales onto the form. I did this successfully but I had this nagging fear that there was so much tension in the wood that once ribbed, and planked, that there would be deformation once the canoe was off the mold. So, I removed the clamps, allowing the stock to straighten back out. They retained virtually no shape from having been dry-bent! I steamed each end with the plastic bag method quite successfully and clamped to the form.
Working alone I steamed (in a standard steam box) enough ribs to do the middle third of the canoe. After shimming the rib tightly under the strong back, I first bent one side and spring-clamped to the inwale, then quickly went to the other side and repeated the process. I think it's conceivable that the second bend had a bit more resistance than the first side due to cooling, but I had no problems other than one rib which catastrophically failed due to poor grain structure. I later went back and pre-drilled, then nailed the ribs to the inwale. The second day my brother assisted and we easily bent the ribs together, again first clamping then going back and nailed. Our third session ended abruptly when my steam vessel ran out of water prematurely (guess I had the flame up too high), and we both smelled smoke. In spite of that, we pulled the ribs out one by one, and had no issue bending on 11 ribs that only had residual steam in the box. All that are left are about 5 ribs at each end, albeit the ones with the most radical bend at the stems!
That looks nice Patrick. I hope we can get the rails on the school’s AT form without steaming. I’m not sure what species of spruce we have. It was cut locally a long time ago. I guess if we have to steam we’ll follow your example.
Tim, I have no doubt that you'll be able to dry bend your spruce inwales successfully, providing the grain structure is consistent. On my first attempt I used local spruce and had one side fail due to a spot of twisty grain. I suspected it might be problematic and, of course, it was! I decided to take no chances with the nicer Sitka spruce pieces I used on round 2.
I tapered my inwales to about 1/4" in width at the stem which I assume makes them more flexible, but at the same time perhaps more fragile.
Love to see the Atkinson Traveler forms and canoes! Assuming there are no major defects in the rails there should not be any problem in installing the rails dry on the form and the same for the outside rail. If there is a defect in the rail, like on Patrick's boat, then steaming the rail will not help at all. I do like the looks of the tapered, in width, on the inside rails. It does make the rail tips a bit more fragile but just until the decks are in place.
Since I have the attention of the Atkinson Traveler designer, Mr. Thurlow.... I have a question. Should there be an additional steamed rib on this form, or am I ready to plank with cant ribs to fill in the rest? I have not notched the stem for another full steamed rib yet as I was unsure....
Keen observers of the fourth picture above will notice that both a Stelmok 15' Island Falls Willow (above) and a Northwoods Canoe (in progress) are in the same picture!
Yes, I would go ahead, notch the stem and add that last rib. Good looking rib stock with nice tapers on the ribs, well shaped stem and rails. It looks like the making of a great wooden canoe. Nice looking shop but the floor is too clean.
Thank you!
My 'shop' is a Pennsylvania German bank barn, built for dairy farming. The second floor, level with the upper bank, is divided into 3 bays with my active workshop area in the former threshing floor where hay would have been brought in for later storage in the two side hay mows. There's a trap door in the floor adjacent to my bench vise where hay could be dropped through the floor to the waiting cows below. The rough flooring in the center bay is doubled to accommodate the weight of wagons and hay and has seen lots of wear over the last 150 years! I like the patina but it does make leveling sawhorses and rolling my form cart somewhat problematic. I do occasionally sweep and vacuum the floor to keep up with the debris... although it is pleasant to walk in after a session of using the hand plane for paddle making or inwale tapering and see the curls of wood on the floor!
After a week away working in Vermont, I returned to the barn/shop and at Mr. Thurlow's suggestion I steamed and installed the last, sharpest rib bends at the ends of the canoe. Logic suggested that a strongback directly over the stem recess would allow me to insert shims to tightly hold the rib to the stem and inhibit splintering. So I bandsawed a 2x4 scrap and fastened it in place at each end.
Next I set up the steam rig with a plastic bag this time to accommodate two previously bent ribs from another project which didn't work out for that canoe. These had been bent over a Chestnut Bobs Special for replacement and were in good shape other than that they didn't take the final shape I wanted to fit inside the old canoe. I assumed there would be breakage so I would make my first attempt at this sharp bend with ribs that were already 'discards'.
Once steamed for about 40 minutes, I knew the ribs were ready because the shape of the ribs had relaxed in the steam to nearly straight again! I removed the first rib from the bag, placed and shimmed under the strongback, lo and behold.... the first one bent like a limp noodle with absolutely no problem or splintering! Stunned but emboldened, I grabbed the other 'discard' rib and repeated the process with the exact same result. I had been dreading the possibility of damaging several rib blanks and here I felt like some sort of pro!
Now... it's on to planking. Ribs were faired with a 60 grit long board sander I made from two slabs of 3" wide Masonite and rib-stock paper holders under two newel post knobs screwed through the masonite:
I struck a centerline on the canoe, selected and laid out the garboard strakes, and will commence planking tomorrow. In Thurlow & Stelmok's book, Building the Wood Canvas Canoe, Jerry Stelmok describes using 18ga. steel nails to fasten the planking to the stem in between ribs. I was surprised at this, though in each of the restorations I've done the planking was nailed into the stems with steel. Planking which crosses a rib at the stem gets bronze ring shank nails. I'm wondering if 5/8" nails, pre-drilled, are sufficient for this?
Patrick, when I had a question about the tenacity of my ring nails, I did a test with a scrap of rib and a scrap of inwale. I was not able to dislodge the nail without destroying the wood first. But if you need bigger nails, Fairwind Fasteners has bronze ring nails in 3/4", 7/8", 1", etc lengths.
And I couldn't help but notice the narrow paddle in one of your shop pictures. I made two earlier this summer that were 5-1/2' wide because that was the width of the stock I could get!
Worth, I favor narrow paddles for deep water lake paddling. Of the six paddles I've made only one is 'wide', and that's a traditional beavertail blade which I mostly use in shallow water in order to get more blade area in the water. The narrow blades are more benign for my shoulders for all-day paddling.
Here are two Cherry paddles made from the same board, my interpretation of an ottertail on left and beavertail on right.
This one's an American Sycamore of my own design, about 5" at the widest point of the blade. It's got a grip design I shamelessly copied from a Sassafras paddle made by Al Bratton of the WCHA.
Here's Al's Sassafras paddle on the right; also a narrow blade and quite lightweight and flexy. One of my favorite paddles.
You are right in that the planking to stem fastenings should be the 5/8" bronze ring nails. It also helps to predill with a 1/16" bit.
When Jerry and I wrote the book the shortest and smallest bronze ring nails that were available were 7/8" #14 which were way too long and way too big for the stem work and that is why the small steel nails were recommended but followed up with a #14 bronze ring nails that would need to be predilled with a larger dill bit and the nail cut shorter so not to come all the through the stem. It wasn't long after the book came out that I bit a risky bullet and custom ordered 100 lbs of the 5/8" #15 ring nails. The demand for the nails increased over the years so that Standard Fastenings started to put them in their catalog so now they are fairly easy to get but not possible in 1986.
Some progress. Planking on the form is now complete, the half built canoe lifted off the form, cant ribs installed, inwale/stem joints complete. It is interesting to see the inside of the canoe for the first time... and recognize some minor mistakes made! There are a couple of phillips head impressions left on some ribs from the metal band fasteners which will need sanding out. My bronze 7/8" nail points penetrated through the stems where ribs were nailed to them. They are now filed off and are now part of the character of the canoe.
Off the form:
Excess rib tips cut off:
Ready to finish planking:
You might be able to "lift" some of those out by using a wetted cloth and an iron. I have removed lots of dents from wood using steam.
If the heads of those screws are proud, lesson learned. You will occasionally find folks putting tape over the galvanized, to keep it from bleeding into the wood, but that could also help with those Philips heads.
The canoe looks great!
Thanks. I'm very pleased with the canoe so far. It's my first new build and in many ways easier than the restorations I've done previously. I have to admit it's pretty cool to stand back at each phase and gaze in wonder at how one starts out with straight stock, and after manipulating it in arcane ways, the result is a pleasing blend of complex curves.
Yes, I had planned to wet those spots with hot water and an iron if necessary. The imprints aren't deep, but I am sure varnish will highlight them if I do nothing!
It 's a question for me , why bending branches on canoe and chose turned root-trunk for another native boat ?
and why bending a complet branch when two half are better strong ? native dont change a broken stem , they tyed it and it's stronger
like bendind "plywood" before gluing
View attachment 56930View attachment 56931View attachment 56932View attachment 56933
首先道歉;我已经在几个地方发布了关于这个项目的信息,但现在没有连贯的整体构建帖子。
等了很久才买到 18 英尺的内舷板(锡特卡云杉)后,我终于开始着手这个项目了。从我的阅读中,我了解到,将内舷板干弯到模具上是很常见的做法。我成功地做到了这一点,但我一直担心,一旦肋骨和木板成型,木材中的张力就会太大,以至于独木舟脱离模具后就会变形。所以,我取下了夹子,让原料恢复原状。它们几乎没有保留干弯后的形状!我用塑料袋法成功地蒸了每一端,并将其夹在模具上。
我独自一人蒸了(在标准蒸汽箱中)足够的肋骨,以完成独木舟中间的三分之一。将肋骨紧紧地垫在坚固的背部下方后,我先弯曲一侧并用弹簧夹紧在内舷板上,然后迅速转到另一侧并重复该过程。我认为可以想象由于冷却,第二次弯曲比第一侧有更大的阻力,但除了一根肋骨因颗粒结构不良而灾难性地断裂外,我没有遇到任何问题。后来我回去预先钻孔,然后将肋骨钉在内舷板上。第二天我哥哥帮忙,我们很容易地将肋骨弯曲在一起,再次先夹紧然后回去钉上。我们的第三次训练突然结束,因为我的蒸汽容器过早用完了水(猜是我把火焰开得太高了),我们都闻到了烟味。尽管如此,我们还是将肋骨一根一根地拉出来,11 根肋骨在弯曲时没有出现任何问题,这些肋骨只在盒子里残留蒸汽。剩下的肋骨大约在两端各 5 根,尽管这些肋骨在茎部弯曲得最厉害!
Excuse me, I’d like to ask a question. For the boat you built, does it not require any glue? How do you handle the small gaps and seams between the joints?
Welcome Vinci,
Construction of a wood & canvas canoe is very different than that of a strip canoe, as shown in your Avatar. The strip canoe is indeed glued.
These wood and canvas canoes are not glued. We use brass or copper tacks to hold the planking in place.
The builder makes an effort to butt the planking, but since water tightness is not a requirement, gaps are not a problem. Adhesive is never used. Once the hull is finished, it is covered with a canvas that is then stretched, filled and painted. That is the waterproof element in this style of build.
I have (as do others) numerous old canoes that with large gaps between the old dried out planks. Aside from an aesthetic consideration or the likelihood of sand and detritus finding their way under the canvas, there is no harm in this. As long as your lunch won't get lost in the cracks, it's fine.
