Is this to far gone for just paint?
JohnH
Curious about Canoe Design
I have been striping this Old Town Scout down. Well I think it is a Scout. It has the extra short rib in between the full rib on the floor. No decal.
It might float with just paint on it.
Most of us on the forum would recanvas, fill, and paint…all new. But prior to that we’d make all necessary repairs, strip ,sand, and revarnish the interior. The best time to do that is with canvas off. IMHO now is the time, brother!
I guess it depends on your goal. A Floater? Or a floater that looks like someone has taken care of it.
The key questions are how badly it leaks and your objectives as Dave suggested. What does the deck look like and can you share the serial number? Thanks,
Dave,
My dad use to say. "Your in a boat, what else do I have to do besides paddle and bail it out."
A lot f history in this old boat for me. Maybe someday I or someone else would like doing that.
Replacing canvassing would be best practice.
Benson,
It didn’t leak much before I started removing paint with a heat gun but it was cracking bad.
#159789
The Mighty Mo, She can make you feel very small.
You can easily paint it and see if that will give you another year or so.
The Old Town canoe with serial number 159789 is a 16 foot long, CS (common sense or middle) grade, Yankee model with half ribs, and a keel. It was built between April and October, 1953. The original exterior paint color was dark green. It shipped on July 9th, 1954 to Columbia, Missouri. A scan of this build record can be found below.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. Page 11 of the 1954 catalog at https://www.woodencanoe.org/_files/ugd/537308_1114e7b1c8f541d480d8ff52c4eb10e3.pdf has more details. Feel free to reply here if you have any other questions. Thanks,
Very cool '53 Old Town! I wish the Chestnut Canoe Company had records like this. That's fantastic! :cool:
Hey, are you on the Marshall Amp Forum @JohnH?
here are a few links you might check that deal with painting over cracked and chipped paint and filler, some with before/after pics:
sanding or not (before painting a cracked surface)
http://forums.wcha.org/showthread.php?6607-sanding-or-not&p=35286#post35286 post 3
restoring paint/canvas
http://forums.wcha.org/showthread.php?9626-My-first-wood-canoe&p=50987#post50987 post 6
http://forums.wcha.org/showthread.php?t=5790 see pp. 2-3 of this thread
http://forums.wcha.org/showthread.php?7619-time-is-not-on-my-side!&p=40689#post40689 post 3
http://forums.wcha.org/showthread.php?8564-Smoothing-Canvas/page2 starting at post 12, on bondo spot putty
It is possible to put off the inevitable, a fresh canvas, but for your canoe, it may already be too late for that. The cracks showing in your filler and the inside images suggest that it has been leaking quite a bit. That is what happens when the filler eventually fails. Even carefully applied paint will not prevent it from leaking. Not only are you dealing with the cracks in the filler, but it looks like the area around the keel is allowing water in.
The only fix for that (unless you do decide to embalm it with gluvit) is a fresh canvas.
Thats not such a terrible thing. The varnish is also in desperate need of stripping and reapplication to protect the wood. If that were one of my canoes, I would lean towards refinishing it now while it is still in nice shape. Cupped planking is not fun to deal with.
Thanks everyone,
I think you are right the canvas is to far gone and I would be unsatisfied with it. I only used it a couple times with my wife to watch the sunset on the Missouri river and a couple other short trips. We never used it in the college classes while I was there. There were several other even older ones that were stored in the boat house. We did use some that were in better shape. They closed down the classes in the late 90s and auction of all the canoes and sailboats.
Best practice would be to strip it down to bare wood.
I am still up in the air about finishing up the whirly gig.
