Oak stems
At the Wooden Boat School in Havre de Grace, since I've been going there we have replaced several stems and always used oak. Start with a square or rectangular billet slightly bigger than you need. Sand it - no rough edges. Soak it for a week. Steam it for something like 45 minutes - maybe more. As soon as it comes out of the steam box, and paying attention to the grain of the wood, tightly clamp onto it a strap of steel with a 'stop' at one end. We have a form which approximates the curvature of a stem, and there are several holes along it for attaching clamps. The hot wood is laid up against the form, clamped on one end, then bent against the form, clamping as you go. Usually this is left to dry for a week before unclamping. About half the stems I've seen bent this way will have a few cracks along the edges (like hang-nails), but not so bad as to make them unusable. Sometimes there is a bad break. Make and bend more billets that you expect to need. This is an oversimplified explanation. Tom McCloud
