Wondering about 94459 16
RRHenseler
The Canoeist
I'm considering a canoe marked 94459 16 on the inner stem, and am wondering about its build record.
Thanks in advance.
The Old Town canoe with serial number 94459 is a 16 foot long Yankee model in CS (Common Sense or the middle) grade with red western cedar planking, open spruce gunwales, ash decks, ash thwarts, ash seats, half ribs, and a keel. It was built between April and May, 1927. The original exterior paint color was N. H. (New Haven?) green. It was shipped on May 31st, 1927 to the Wisconsin Veterans Home. The back side of the record shows that it appears to have moved to Green Bay, Wisconsin by September of 1972 when there was a previous request for a copy of this information. Scans showing both sides of this build record can be found by following the links at the attached thumbnail images below.
These scans and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.php to renew.
It is also possible that they could have another number or manufacturer if this description doesn't match your canoe. Feel free to reply here if you have any other questions. Good luck,
