There's a supermarket chain here that has some special offers on tools from time to time. Their prices are very good and the quality is said to be not so bad either, normally.
Now they have a thickness planer for around 250$ and I'm wondering if this is something worth buying or better to pass on it..
Some technical data:
1200 Watt (240V)
9000 rpm
2 blades
max cutting depth 2mm (5/64")
max width 200mm (8")
max wood thickness 100 or 150mm (4" or 6", I don't remember exactly)
cutting speed 5 meters/minute (16'/min)
weight 25kg
Do you think this is something useful or a waste of money? How much power do you consider appropriate for a thickness planer?
I know a professional item would be much better, but even used ones go for much more than that. On the other hand, if it doesn't do the job reasonably well, it's 250$ too much.
Intended use for canoe building of course, e.g. planing wood for strips or planks, gunwales etc.
Thanks for your input
Thomas
1200 Watt (240V)
9000 rpm
2 blades
weight 25kg
Thomas
