Screw Hole Filler Material
enggass
What is this filler called? see the filled holes in pic... And what is the best way to remove it?
options
Looks like some kind of body filler, bondo or mud daubers or something? You could drill them out and then plug them. But you could also use the holes for a line and attachment points. I have a plug cutter for patching holes. You just find a similar piece of wood that matches and drill the plug out of it, glue and saw it off flush, sand, etc.
