Tony Denton
I am working on a very interesting double ended rowboat, 15' long and built like a chubby canoe. It has an i.d. ZLD 111280582 but no maker's name, and is probably Canadian because of the Robertson screws.
The beam is 43 and a half inches, depth 17, the gunwales are 1" square ash and the planks are white cedar and quite thin, maybe 5/32".
This is a well made boat which raises some interesting questions about using ash. It has obviously been left lying on the ground, and there is rot in the ash which seems to have worked from the inside of the inwales. They look good from the outside but you can poke a finger into them, and when cut off the pieces are extraordinarily light.
The recanvassing/restoration is in the early stages and I should have a better idea of this boat later, and in the meantime would be interested to find out who made it.
