samb
I was really excited to borrowed a cheemaun form. To you guys in the US & Canada, it might be common to be able to borrow a form, but in the UK it is not. This is the first I've seen and only know of a couple of others.
Along with the scarcity of forms is a scarcity of white cedar so I am having to use red. The home grown red cedar is quite knotty so I am having to use imported.
I managed bending the ash inwales and stem with no problem. I used steam and compression straps. This morning I tried a dummy run on a rib and although it certainly wasn't a failure, I'm not too happy. I decided not to use a compression strap because I'd be limited to how many ribs I could do at a time. The rib was slightly thicker than I intend to use. I soaked it over night, steamed it for 15 minutes and bent it using the technique described by Rollin (well it is his design after all). Everything went well, I thought, but I've ended up with what look almost like small creases on the inside of the curve.
Did I soak for too long / not long enough?
Did I steam for too long / not long enough?
Did I bend too quick / too slow?
Should I have used a compression strap?
I'm sure there must be an explanation. Can anyone help or are these marks expected? Would I be able to sand them out - or is it sign that there is now a weakness at that point?
Any ideas would be welcome. You obviously have the knowledge and it's probably on the forum some where but I just can't find it.
Thanks.
Sam
Thanks.
Sam
