Once the rib has been bent around the bottom of the canoe, what is the proper order of tacking it to the inside of the canoe? Does one start at one side of the rib and start taciing towards the middle and then towards the opposite side? Or does one start in the middle and work towards both sides? I assume it is best to use the old tack holes and drill a small started hole in the rib and then clinch the tack. I'm sure this is a two person job, except maybe for the sides. Need some advise with this part of the project. Steamed and bent the ribs without any problems, but securing them to the canoe is a first for me. Thanks for your help and advise. Ron.
