Howie
Wooden Canoe Maniac
My Rushton IG's outer rails do not have a rabbet. That is, the side of the outer rail that rests against the canoe is flat and the planking extends all the way to the top of the inner rails.
So the question is: Where do I trim the top of the canvas? If I trim to the top of the rails the unpainted inner part of the canvas will be visible - plus the trimmed part of the canvas is always a bit unsightly. But if I trim the canvas to be a bit lower than the tops of the rails then there will be a gap - especially where the tacks/staples are. These problems are solved if I trim the canvas closer to the bottom of the outer rail, but I risk making a mistake and trimming below the outer rail.
I was going to write that I'm certain the rails are original, but now I'm wondering. The serial # is 5213 - maybe 1915 or so? - so it's not as if the company was slacking off. The screws holding them appeared to be brass, but I guess that tells me nothing. They are certainly well shaped with a nice D profile, and they were steamed to perfectly fit the canoe's profile. The canvas was long gone when I got it, so there's no clues there.
I'm afraid the pictures I took of the canoe when I got it are not much help. When restoring I removed all the top planks (because I had to replace all the rib tips), and I have no recollection of where the top edge of the top plank came. When it came time to reinstall these top planks I did note that some did not extend to the top of the inner rail while some did. I assumed that this was an indication that I didn't get the height of the inner rails exactly right when I reinstalled them. Anyway, I repositioned the top plank's edge to be flush with the inner rails. But now I'm wondering if the top of the planks really did end maybe 1/4" below the inner rails, and maybe the canvas was folded somehow in this 1/4" space between the inner & outer rails?
Thoughts?
Thoughts?
