OT #145596
Andrew
Assuming this is an 18' square end-paddling canoe w/ sponsons.
I'm told it was recently restored and covered in fiberglass, but I haven't seen it yet. Thinking this is one heavy canoe!
The Old Town canoe with serial number 145596 is an 18 foot long, CS (common sense or middle) grade, square end paddling model with open spruce gunwales, ash decks, ash thwarts, ash seats, half ribs, a keel, outside stems, sponsons, and a rowing seat. It was built between June and August, 1946. The original exterior paint color was dark green. It shipped on August, 7th, 1946 to Thomaston, Georgia. A scan showing this build record can be found below.
It is also possible that you could have another number or manufacturer if this description doesn't match the canoe. The 1951 catalog page at http://www.wcha.org/forums/index.php?attachments/15062/ lists the weight at 130 pounds without sponsons. Feel free to reply here if you have any other questions. Good luck,
Thank you, Benson! Looks to match the photos I received.
