Old town # 93683
The Old Town canoe with serial number 93683 is a 16 foot long, AA (or top) grade, Ideal model with red western cedar planking, open mahogany gunwales, mahogany decks, mahogany thwarts, mahogany seats, half ribs, a keel, a mast seat and step. It was built between February and March, 1927. The original exterior paint color was brown to match a sample that was provided. It shipped on March 30th, 1927 to Inwood-on-the-Hudson, New York City. A scan showing this build record can be found below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will donate, join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-wcha to learn more about the WCHA and http://www.wcha.org/store/membership to join.
It is also possible that you could have another number or manufacturer this description doesn't match the canoe. Feel free to reply if you have any other questions. Good luck with the restoration,
Thanks Benson. I will have to look harder at the number. It is very difficult to see. This canoe has all ash woodwork and does not have a mast seat. I'm not sure what the step means. Also the deck has caps on the rails that I have not seen before. I'll post a picture of these when I get a chance.
Please post some pictures of the serial numbers from each end and the deck shape. The picture below shows a mast seat and step from that era. Short rail caps on the decks are frequently found on Kennebec canoes and on other builders' canoes occasionally. Thanks,
