Old Town 173426-18
The Old Town canoe with serial number 173426 is shown as an 18 feet long, CS (common sense or standard) grade Guide model equipped with a keel. The canoe was built between October 1963 and February 1964. The original exterior paint was Guide Special green. It was shipped to North Conway, New Hampshire on June 4, 1964. There was an inquiry about this canoe on March 1, 1980. Scans of this build record can be found by following the links behind the thumbnail images attached below.
[Our server is not allowing me to post the build record now -- I will try again later. However, as is common in the 1960s, no woods are specified on the build record. Odds are that eastern white cedar was used for the ribs.]
Greg
Thanks for quick response. Some work was done it in the recent past (not very well I might add), hence more ribs need replacing and the usual ends are rotten. Want to bring it back to as close to original as possible, hence questioning the type of wood used.
Northern White cedar not Eastern for ribs. Planking would be in Western Red Cedar. If the gunnels are spruce then most likely to be Sitka.
Here are the records Greg wanted to post.
