Ray Kepler
Hi,
I’ve started glueing up my first paddle and plan to do many more. My question is about fiberglassing. Should I or should I not? Is just using some Spar urethane OK, or will fiberglass be worth the trouble? If I go with fiberglass, what would be a good, recommended weight and epoxy to use? Or should I spar it and glue on a hardwood tip?
Thanks for any advice.
Ray
Ray
