Information request, Peterborough?
Hal Wilson
Hello,
New forum member, here, with a hearty hello to the information volunteers.
I've got a refurbished/recovered canoe i believe is a 1932 Peterborough. Serial number is stamped inside: C10556. Any help with cofirmation would be greatly appreciated. Thanks, Hal
Welcome to WCHA,
The serial number you posted is not a Peterborough Canoe Co model/serial number. It is likely a Chestnut Canoe Co serial number. To help identify the model and possibly the canoe's age, please post the canoe’s measurements; length, width, centre depth and the size and spacing of the ribs. A couple of pictures of the canoe and its interior would also be helpful.
Dick Persson
Headwater Wooden Boat Shop
Reply for Dick Persson
Hello again from Hal,
I'll describe the canoe as you suggest, as best i'm able, and post pictures when available. Boat legnth is 15 feet; width at center, 34 inches; ribs are spaced at 1 1/2 inches as the ribs themselves are 1 1/2 in.; depth is appr. 13 inches. I hope that helps. Thanks again. Sincerely, Hal
More info for Dick
The boat, i must add, has a wooden skeg or keel, which runs almost the full legnth of the boat, if that helps? Thanks again, Hal
Without pictures I can’t make a positive identification.
However, the Chestnut “Chum” model is 15’ x 33” x 12” and have ribs 1½” wide spaced 1½” apart. Did you measure the width from outside of the hull at the widest part, but not including the outwales?
Dick Persson
Response for Dick Persson
Yes, i measured on the outside of the boat at its widest; slight tumblehome allowed a rough measure, but it was more than 33 in. and a little less than 34. Tomorrow looks like a sunny day around here, i''l take some pictures and post. Again, thanks. Hal
