I.D. Help #9351 O.T (?)
hillierkim
Need help with build record for what appears to be Old Town sixteen footer. Number is 93513 16 . It is fitted with bilge keels and bow and stern carry handles. Thanks in advance....Kim
Kim: The Old Town canoe with serial number 93513 is a 16 foot long, CS grade, OTCA model with a keel, bilge keels and half ribs. It was built between January and March 1927. The original exterior paint color was cherry. It shipped on March 23, 1927 to Ann Arbor, Michigan. A scan of this build record can be found by following the link at the attached thumbnail images below.
- Al
