I am new owner!
The Old Town canoe with serial number 184516 is a 16 foot long Wahoo model with a lateen sailing rig, white decks and a white hull. It was built between February and March, 1970 and shipped on April 2nd, 1970 to South Berwick, Maine. The back side of this card indicates that there was a dry spot which was starved of resin on the right bow. Scans showing both sides of this build record can be found by following the links at the attached thumbnail images below.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. The build records are the only information that has been preserved so the original invoice is not available. I have a nearly identical Wahoo near Portland, Maine if you want to see how it all goes together. Feel free to reply here if you have any other questions.
