Jim, Thanks. When the "Margaret R" was completed, Martin Van loaded the dory on the trailer he had bought and modified (removing a couple spring leaves to weaken the springs so the mere 150-so lb. boat wouldn't bounce all over the road) and drove it over to St. Paul. Wonderful fellow.
I had first talked to Martin about his Rangley guide boat, but he suggested the sailing/rowing dory. Oars of Sitka spruce, it's so light it's like rowing a leaf. Single-mast, sprit rig. Simple to set up. Apparently, if you're caught in a serious blow and need a sea anchor, you just secure the sail line to the boat, then lift the mast and sail out of the seating and throw it overboard. Steady as she goes, Mr. Bush!
I showed the dory to a friend from Alaska, and he said ... "hmmmm. coffee table." Marine mahogany and cherry. Almost time to get it out on a local lake!
