Double Blade Paddle
Craig Johnson
Lifetime member
A while back I was soloing when the wind picked up. Wasn't to bad but I was tired and didn't feel like I was making much progress. Both of my paddles have long flat grips so I tried holding them together and using them like a double blade paddle. It worked pretty well so I decided to try to make a couple paddles that would clip together. Here is what I came up with. The cam locks are deer antler. Paddles are sassafras.
Too much time on my hands I guess.
Just polishing up my skills before I start in on that American Chestnut I got from Andre. Thats next.
Just a bit of genius in that. Well done!
I've lashed two paddles together, to get the same effect, but that was simple. This is a whole lot more solid...
Lovely Project
What a beautiful paddle! Do you think I need one of these? Or should I concentrate on the J-stroke -- using a longer slimmer blade?
Thanks Millie. Stick with learning to control a canoe with a single paddle, a double blade is a poor substitute, although useful in some circumstances.
As skills are developed with the single-bladed paddle, the perceived need for the double-bladed paddle decreases. You reach a point where the only time you might need a double-blade is going upstream, and against the wind. But a canoe pole works better than a double-bladed paddle...
I modified a Greenland kayak paddle by lengthing it to about 9' ( scarfed in a bit of wood) and turning it into a two piece with one of the Duckworks ferrules. Just the ticket for taking my Jerry Stelmok Willowwisp up wind on a big lake. Narrow blades mean no feathering, and little windage; the canted Greenland forward stroke works fine until the gusts are hard enough to stop you in your tracks.
My Dad made a Greenland style paddle from a spruce two by. It's not as elegant as a true Greenland, but it's light and flexible, with blades slim enough to be easy on the shoulders. It's my favorite paddle.
