Ceconite
Peter,
Is your "barrier to adhesion" trick some other material like wide saran wrap laid over the surface of the hull before the ceconite is applied and shrink fitted? Without an underlying barrier, does the ceconite adhere as a result of the heat shrinking process or from bleed thru of whatever you are using for weave filler?
Ed
			Peter,
Ed
