canoe Identification: Kennebec?
lboeye
I am still looking for help with an identification on this canoe,( see earlier post ). Further work has perhaps revealed some additional clues:
The canoe appears to have had sponsons connected at every fourth rib. (Photo DSCN072)
The stems are oak and bear no numbers, but they are 3/4 inch, and show screw holes that do not line up with the existing stem band. could it have had an external stem? ( Photo DSCN1082 )
I am not familiar with long deck canoes, so is framing with the two end ribs free floating typical? ( DSCN1069, DSCN1077 )
Would the direction of the planking possibly be a clue to its identity? ( PhotoDSCN1079 )
The seats and thwarts appear to be original, and all of the trim is mahogany. ( DSCN1088 )
Any help would be appreciated.
Larry Boeye
I will attach a picture of a thwart and seat from a RacineWis canoe I once owned.
Did the person you bought the canoe from say why it was believed to be a Kennebec? Do you know where it was found?
Second choice Racine,
Need more pics of rib tops and true shape of the top of the thwart.
Paul
photo 1079 shows a very wide shear plank as it extends into the upsweep of the canoe. This suggests Racine to me. If the shear plank is perfectly horizontal with a joint at the approx. center, then it most likely is a Racine.
