Larry, would you mind expanding on this a bit?
Cliff;
Out West here, for some of the woods needed for faithful restorations, the patience of a saint is required - and sometimes divine intervention as well.
Much wood shipped sight unseen turns out to be unusable.
Even our plentiful Western Red Cedar is hard to find in the sizes and quality needed for some types of boats. It is not unusual for old rowboats to have garboards or sheerstrakes of flawless perpendicular grain (no conspicuous radius to the rings) cut from boards over 14-inch wide. Allowing for removal of heart & sapwood, that requires a tree 4 feet or so in diameter. Such of those available now have 4 to 6 growth rings per inch, not the 10 to 20 RPI of old-growth wood. The 'young' wood also lacks the extractives that impart rot resistance. The difference is profound.
Fastenings are an interesting case. two examples:
* I measured and recorded one old rowboat (of an extinct commercial type called a hand troller or handliner that I am much interested in) that was put together with 1-1/4" skinny tack-type fastenings that are definitely iron, but which are still quite sound after 60 or 70 years (exact build date uncertain). The boat has been in frequent use for most of its life, always in salt water. I badgered existing manufacturers for information on what these fastenings might be, even dragging some old guys out of retirement to correspond. Nobody could tell me for sure what they were. The best guess I heard was that they are some kind of "Swedish Iron", a sort of wrought iron that was in use by the Vikings, which rusts very, very slowly (it apparently surface seals, like corten steel). Restoring this boat with original-type fastenings appears to be impossible unless I chose to have replica fastenings hand-forged and formed. A Vancouver chandler's catalog from the late 1940's (which was probably available to the builder of the boat in question) listed fastenings referred to as "tinned iron tacks" that might be the thing used, but no manufacturer or other helpful info was listed.
Tinned iron tacks were also used on the cheapest grades of wide-board canoes.
* Canoes on the West Coast here are frequently used in salt water, so should really be put together with all copper and bronze fastenings, not brass. Proper canoe tacks with round/domed heads do not appear to be available in copper anywhere now. They used to be. The flat heads of available copper tacks are less satisfactory - they require an extra step to set down properly, and are far more vulnerable to accidental head removal during later repairs & refinishing - the heads are thin enough to be easily sanded off.
Larry Westlake
