1927 Old Town 50#
patrick corry
solo canoeist
I included some pictures of this future restoration project here:
This should be a fun, somewhat historic, project. Sold to Mrs. F. B. Trudeau of Saranac Lake, NY who was the wife of Dr. Trudeau famed for his early research into tuberculosis and the curative powers of the Adirondack air. Dr. Trudeau's study of rabbits on tiny Rabbit Island within Spitfire Lake near the Paul Smith's campus formed the early basis for his research which evolved into the modern Trudeau Institute. Early on the Trudeau family resided at Paul Smiths Hotel, then permanently moved to Saranac Lake. I'm hoping to have this project complete for the 2027 Assembly, presumably at Paul Smiths College again, for its centennial splash in Adirondack waters!
The canoe made it's way over the years to Ten Mile River Boy Scout camp in Sullivan County, NY and eventually to the gentleman from whom I got it, who was a former CEO of the American Red Cross in metropolitan New York City.
That is very cool. You have to wonder who might have paddled it back in the day. Was it's first paddled on Lake Flower?
But it was delivered to Lake Clear Junction, which is also very cool and certainly a motivation for you to bring it to assembly. Maybe it was paddled from Lake Clear to Upper Saranac via the outlet and then on to Saranac.
The stories sometimes really are fun to invent.
Yes, as I have found my way to this ... hobby (obsession)... along the way I discovered that the history and stories behind the canoes, and the people I meet along the way are just as much fun as the canoes themselves.
Here's a little progress on the 1927 50#:
Before any work:
Two 50#ers came home from Yorktown Heights, NY
The 1927 Trudeau Old Town 50#er
Rib tip repairs; As I did the worst tips, then reviewed the remaining rib tips, I kept on finding more to repair. The inwales were nailed with steel nails and every tip was either nail-sick, split, or rotted from poor treatment during the canoes life. Therefore I ultimately repaired every tip! In retrospect I suppose I could have just cut off about 5/8" from every tip and lowered the sheer.... but I didn't think of that until I was halfway through the tip repairs. Stem tips have been repaired with Ash and a hardwood spline glued behind the stem to reinforce the joint.
Inwales are in horrible shape, but i'm going to attempt to scarf in new pieces- inspired by Chris Pearson's work- thereby retaining as much original material as possible. There were lots of modifications & amateurish repairs, and it was sort of hard to discern the original seat and thwart locations until I scraped multiple coats of paint; the inwales have been white, green, red, and orange over time. Interestingly, my diligent paint removal allowed me to see the impressions of the seat hanging dowels where they were impressed into the underside of the inwales. I finally was able to understand the orientation of all penetrations. Here we're looking at the underside of the inwales.
For the sake of continuity in the restoration of this canoe I am adding this link from a recent discussion about the planking on this canoe.
I will continue to add to the thread as the project continues.
Yesterday I bought two pieces of wood... clear vertical grain Western Red Cedar (nominal 1x12x12') and a piece of Sitka Spruce, true 2"x6"x16' perfect straight grained and rift sawn. I nearly had a heart attack at the cost! After ripping the 1x12 into three pieces 3.75" wide, then with careful positioning of my table saw fence I was able to yield 3 rough planks from each piece. The final yield was 9 pieces of planking (yet to be dimensioned to thickness with planer) each 12' long, so 108 lineal feet of material at a finished cost of $3.21/lineal foot; not including my labor of course... but that has no discernible value these days as a retired person.
The Sitka Spruce will make inwales and outwales; enough for 12 pieces rough cut to 13/16' x 1". Cost per inwale/outwale blank; $22.25. Here's my drawing of why I chose rift sawn. My last spruce outwale set was like the top drawing, and I didn't like it. The rift sawn stock should produce an appearance that appeals more to me.
Progress has been made:
I've removed, cleaned, and re-installed roughly 80% of the original planking; even some which has damaged exterior from some prior owner's removal of fiberglass sheathing. That damage will be leveled and faired with Totalboat Totalfair fairing compound. I'll be careful to mask off the joints between planks so none of the compound fills the spaces between planks.
New inwales were made from Sitka spruce:
Ash decks, center thwart, and seat frames made and sealed with 2 coats thinned spar varnish:
Currently preparing rabbeted mahogany outwales (probably Sapele). It's made of re-purposed house trim called back band which I salvaged from a retiring home builder's shop. I modified it as seen here:
It's not accurate to the original build sheet, but I had it available and it's going to be pretty sharp looking and a great contrast to the spruce inwales! Besides, it can easily be removed and swapped for the original spruce outwales if someone decides to choose accuracy over a bit of color! The unshaped outwale blanks:
Here, a brief wipe with alcohol to illustrate the potential color once varnished:
On the boat, with ends to be steamed into the upsweep at the ends. This is the first time I've made outwales prior to canvas & filler. I'm not likely to canvas and fill until Spring because my shop is unheated, so the outwales will have months to learn their new shape and hopefully retain it while the canvas, fill, and paint goes on next year.
I've made some effort to contact the family of the original owners, to no avail currently, but in the event it doesn't go to them or to the Institute the original owners created (Trudeau Institute, Saranac Lake, NY), I will happily paddle her myself. She's shaping up to be a quite nice canoe!
Patrick, all the money you spend on the wood was completely justified by the fine craftsmanship you did with it!
Haha, you're too kind! I still consider myself a rank amateur at this. Every canoe I've done has had new challenges and I've spent lots of idle hours trying to figure out ways to accomplish a particular task. Plenty of failures along the way but each one teaches me something. I would like very much for this canoe to splash next summer for it's centennial and then have a new lease on life. I'm growing quite attached to it but will give it up as I mentioned above to the right people.
As a side note, when making the seat frames I chose to make them without corner holes for the cane. All my previous seats I have caned had corner holes and there's a bit of discussion here on the forum (use the search function) about caning without the corner holes. My understanding is that Old Town typically did not use corner holes. Yet again, another little wrinkle in the process to figure out. My guess is that there will be no problem; with corner holes you get a "fish mouth"(where two diagonals meet at a corner hole). Without the corner hole you end up with adjacent fish mouths at the two holes nearest the corner.
Here, a single fish mouth entering each corner hole.
Here, two adjacent fish mouths at the end holes.
So, I soaked the Mahogany outwale blanks in an 18' sealed gutter for 10 days. I was surprised how much color leached out into the water!
The outwales were surprisingly flexible once soaked. Remember, these were made from house moldings as described above, and I assumed that the material was kiln dried so that's why I soaked for so long. I steamed the pair at one end only, and they bent on quite easily until the last 3 feet or so, as anticipated, but went on without too much fuss. I then went to the stern and bent the wet (but not steamed) ends on with nearly as much ease as the bow!
Refinement of the outwales will come later once they've set. I round over the top corner, and to a lesser degree at the bottom corner, and also taper in both height and depth as the outwales near the stems. I'll also taper the rabbeted top edge as it reaches the stems; I don't like seeing that rabbet when viewed from the ends at the stem band. I'm planning to drill and screw these on even though there's no canvas yet. I'm hoping the addition of the canvas, filler, primer and paint won't cause the screw alignment to "creep" due to the additional thickness added by the canvas et al. Any of you have experience with this?
I always do outwales before canvas like you. I use steel screws phillips head. That saves the bronze screws from getting damaged. I remove the outwales when I'm ready to canvas. I've never had issues with canvas causing the screw holes to not match back up. they've always matched up just fine. Just don't switch port to starboard.
And may I say, Pat. You really need to mark only one of the wales, though it does require that you recall marking anything. Nice clamping demo and the need for " too " many of them. A nice boat on the way home.
Hi Patrick,
Thank you for the detailed pics and progress. It’s helping as I work through mine.
On stem interface, did you notch the stem to fit the inwales? It looks like your stem comes flush with the top of the deck?
Thanks!
Yes, I relieved the sides of the stem to allow the tapered inwale ends to rest against the "tenon" of the stem. The tip of the deck abuts the stem tenon. The tenon is narrow enough at the top to allow the brass stem band to cover it completely, making it 'disappear'. I searched my photos for a picture of this but couldn't find anything that illustrates it well. These images from Mike Elliot's blog shows a top view similar to the way I do it.
