11" Old Town Trapper, #63394
James Bordeleau
*The above number is incorrect, it was difficult to read. after further review I believe the number is #633943. I did not see the last 3. Sorry for the error i the original post.
Looking for any information about this canoe...Thanks
I went to look at the I.D. number again, I'm now sure the correct number is #63943. The old varnish makes it hard to read. I believe this canoe is all original. I've had several sets of eyes trying to get the correct number. I am certain this number is correct. Thanks for any help with this information search.
The Old Town canoe with serial number 63943 is a 17 foot long, CS (Common Sense or middle) grade, HW (heavy water) model with red western cedar planking, open spruce gunwales, ash decks, ash thwarts, ash seats, a keel, a floor rack, and two spruce slat back rests. It was built between November, 1920 and April, 1921. The original exterior paint color was dark green. It shipped on June 4th, 1921 to Branchville, New Jersey. A scan showing this build record can be found by following the link at the attached thumbnail image below.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. You will need to take another look at the numbers if you have an 11 foot long canoe. The tips described at http://forums.wcha.org/showthread.php?791 may help. Please post some pictures of the numbers from each end. Feel free to reply if you have any other questions,
I sent some pictures to your email
I appreciate any help determining the correct
ID number and any additional info
The number may be 63946???
My guess is that you have the Old Town with serial number 163941. This is an 11 foot long, CS (common sense or middle) grade, fifty pound model with a keel. It was built between August and October, 1955. The original exterior paint color was dark green. It shipped on June 30th, 1956 to Woodmont in Milford, Conn. A scan showing this build record can be found by following the link at the thumbnail image attached below.
The pictures of your canoe show a red decal on the bow deck and pressed cane seats which indicate that it should have a six digit serial number. Please reply here if you have any other questions.
