Strickland Canoe
Here's a close approximation of what's needed, quite a lot of ancillary parts needed but all low tech but I think the former can be in wood. By the time you've made half a dozen, you'll have set yourself up as the supplier for the next twenty years.
Thank you for this will investigate.
Paul,photos as promised:
1st, Sail hole sleeves. I don't think these are what you want. These are from Peterborough Ribs
Next, flag pole holes. This is from a Canadian Canoe Co board and batten
And this is one where I used a plumbing fitting as described a bit earlier in the thread. You can still see the hexagonal key hole for tightening it on, but this can be drilled out. It certainly looks better than a rough hole
Thanks Sam.
The hole is around d 42 mm so the idea from Peterborough Rib would work.
So it is a hole for a mast, not a flag pole. I think spinning the shape would be difficult because you will need a return on the shape. On the Peterborough sleeves they have the main sleeve which lines the hole and the decorative bit you see on the deck is turned back from that. As spinning starts with a flat disc which is then forced over a turned form, I can't see how that would work. Spinning is great fun though. It gets a bit hairy on a larger scale and you must keep the metal well annealed.
I hope to be proved wrong!
I think it is a flag as the the wooden location hole is around 20mm as image.
"As spinning starts with a flat disc which is then forced over a turned form, I can't see how that would work."
Could you not use tube of the same diameter as the hole? Have a former with a hole of the same diameter, tube fixed to it and then spread over?
Charlie.
Charlie.
That could work but I think would be a big ask of the metal. Another solution could be to make a mould, spin the top visible part, cut out the hole and silver solder to a tube
these are what you are after, however they are reproductions turned from brass rather than stamped steel like the original fittings
Those certainly do the job. I had a word with a mechanic friend today, he suggested either spinning the top part and soldering a tube to the inside or by spinning, starting with a flat plate at the bottom of the tube, working up the outside, then the underside of the top part, with plenty of re-annealing on the way.
He felt, if one started spinning a tube, it would have to be seamless tube to get a consistent shape, and then the sharp bend at the top would mean the metal would be very thin at that point.
Hi All
I have recently required a Strickland strip canoe but the brass plate for the flag hole is missing any thoughts as to there I can source one from.
PaulG
