Please and thank you!
chris pearson
Michigan Canoe Nut
Please post build sheet…..
Thanks much!
The Old Town canoe with serial number 46174 is a 16 foot long, CS (common sense or middle) grade HW model with red western cedar planking, closed spruce gunwales, ash decks, ash thwarts, ash seats, and a keel. It was built between October, 1916 and January, 1918. The original exterior paint color was dark green. It shipped on February 15th, 1918 to Chicago, Illinois. A scan showing this build record can be found below.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will donate, join or renew your membership to the WCHA so that services like this can continue. See https://www.woodencanoe.org/about to learn more about the WCHA and https://www.woodencanoe.org/shop to donate or renew.
It is also possible that you could have another number or manufacturer if this description doesn't match the canoe. Feel free to reply here if you have any other questions,
Some additional pictures
