Who made this canoe model?
JPS
Hello,
This large wooden model canoe is one of the items I chose from my dad's estate and would love some help identifying its maker, age, and possible origin.
It measures approximately 41" long × 9" wide × 3" high.
The canoe appears to be quite carefully constructed, with a dark wooden planked/strip-built hull, numerous individually fitted light-colored ribs, contrasting wood gunwales and decks, metal fasteners, and a rope-laced center section.
Most interestingly, “WBC 95” (or possibly similar lettering) is handwritten on at least two of the interior ribs. I am wondering whether this could be a builder's mark/date, possibly 1995, or whether anyone recognizes it as belonging to a particular maker or workshop.
There are also two small drilled holes through the bottom of the hull near the center. I wondered whether these might indicate that the canoe was originally attached to a display stand, although I do not have the stand.
I have not found a manufacturer's label, decal, plaque, or other identification.
I would particularly appreciate any thoughts about:
• whether this appears artisan-made or commercially produced
• approximate age
• whether “WC 95” is recognizable
• the type of construction represented
• whether the two bottom holes were likely for a display stand
• whether this resembles models from any known canoe maker
I don't want to describe it as a salesman sample or attribute it to a particular manufacturer without evidence, so any guidance would be greatly appreciated.
Thank you!
Jennifer
This could have been artisan, home made, or commercially produced. The builder's initials may have been "WBC" and the "95" could be an indication of a 1995 build date. The type of construction is not clear. The holes in the bottom probably indicate that it was secured to a stand, ceiling, or wall at some point. It doesn't resemble any common full sized canoe that I have ever seen. This is clearly not what some auctioneers would describe as a 'salesman sample' from a known manufacturer.
