What have i Got?
I am loving the rolling jig Keith as I am sure are many others. Such a device would save many a back strain as I cannot count how many times I turn a canoe over during a restoration. I also see it being an advantage when varnishing a canoe. A great example of what men in sheds can come up with. Well done, I will watch your progress with interest.
Nick
More investigation this afternoon, I took the stern outer stem off to see how its assembled & look at the plank hood ends.
I had thought the planking was T&G but in fact it is all rebated along its edges, So the nails go through next to the rebate & this holds both planks onto the frame, compared to standard carvel its a 50% saving on nails.
More rotten ribs found, its quite bizarre with some that appear quite sound on the surface being soft & punky underneath or inside, its patchy here there & all over the place. I estimate i'm going to have to replace 90% if not all of them. Typical!
Those last 2 years sitting outside on the previous owners driveway have done her no favours at all.
There are 9 half ribs each end that stop at the apron then 48 full length ones that run all the way across. Several planks are soft under the ribs so there is some planking to do as well.
Fortunately i have a good stock of decent mahogany for planking. A bit of sanding & the planking comes up beautifully.
First job is to number & remove the bilge runners & armouring from the bottom. I am not sure what timber it is, its very pale straw colour & quite hard with very fine grain, It isn't Ash.
Did some chopping out of alternate ribs this afternoon. I had a measure up & had did a few calculations as to weights of timber.
I dont want to use Ash due to its lack of durabilty, in an ideal world Rock elm would be lovely but the last i saw in the uk was some i bought 40 years ago & now long gone! So its English Oak or another option might be Black locust, its said to steam well & is highly durable but its heavy & hard.
But when you run a weight calculation it isnt so different Ash is 42-44 lds a cu ft, locust 44- 48 lds a cu ft Drop the thickness a tad and the weight is the same. Anyone ever used It?
acacia /black locust is rot-resistant wood good choice "if " (yard yew in french to play on words )you can keep it
ash is very tender when it's cut green (splint baskets ) and hard dry , many tools handles are made in this wood
maybee like laurel , very hard in dry place but humidityand there are also brittle
I think i will get a piece & do some experiments, worth seeing how it works & behaves when dry, Black locust is a member of the Pea family as is Laburnum, that was used for bows & i believe was known as "Bois de arc".
A lot of locust is imported from Hungary where a lot is grown for fencing & vineyard posts.
