As has been suggested above, a gloss finish is highly reflective and so it shows surface imperfections better than a non-gloss finish. Options include (1) top-coating with a non-gloss finish, (2) sanding enough to eliminate surface imperfections, and/or (3) filling in the surface imperfections. The planking nect to the ribs ie easirer to rough up when stripping, and whether or not it's roughed up, you end up with less finish there because varnish is going to wick under the rib until that rib-planing joint gets sealed up with varnish. So best bet is first to sand well before applying varnish ("well" doesn't mean aggressively; it means just enough to smooth out as much surface roughness as possible without thinning down the wood too much). Then when applying varnish, build up coats and then sand well, preferably using a backer behind your sandpaper to level the surface. Then keep applying varnish (sanding between coats) until the surface is as level as possible and you're getting little or no wicking of the varnish under the ribs. Doing this fills the valleys with varnish, but it can take many coats. Finally, if you want to knock down the gloss, apply non-gloss top-coats or rub out your gloss finish with coarse cloth, heavy brown paper, ultra-fine sandpaper, etc.
You can get a very nice gloss finish but the hardest part is usually that area where ribs and planking meet. You might consider the compromise of making the interior matte or semi-gloss while finishing the trim in gloss. It's much easier to get a fine gloss ginish on gunwales, decks, thwarts and seat frames, especially if after a number of coats you level the finish by wet sanding with very fine sandpaper.
