paul buettner
This is my first post.  I'm looking for ideas, tips/tricks, etc.  I have designed & made 2 canoes using dacron as a hull covering.  I felt I had been careful especially the 2nd time to fair the hull & get it very smooth.  Then I applied 1 coat of linseed oil.  After it had dried on, I applied the dacron using the method described by Alex Comb in his excellent article "Dacron -- A Canvas Alternative" in Wooden Canoe Issue 142, August, 2007.  I really like the process and the non-toxic, water-borne filler Ekofill from Stewart Systems.  But I would like to correct a couple of small problems if possible.
1) After filling the dacron as recommended and then varnishing the inside of the hull, when I flipped the canoe over again to paint, I noticed a couple of small "blisters" in the surface. These were not evident when applying the filler but only after it had dried on several days while I worked on the inside. I have thought that the cause might be the use of the linseed oil on the hull prior to covering. There may have been a couple of small spots where the oil was not fully dry/cured, and thus leached thru the dacron cloth, preventing the water-borne filler from adhering completely to the cloth in those spots. I'm considering varnishing the outside of the hull next time instead of using oil. Good idea? Or varnish over oil to ensure a dry surface under the cloth? Anything else to do before putting on the cloth?
2) I used 3.7 (or 3.4?) oz. dacron I purchased from Alex. It is very nice to work with, but it DOES NOT hide any imperfections. Even some of the wood grain shows thru the filler and paint (4 coats each). Especially noticeable are planking lines pretty much all over the canoe, plus a few small tack dimples, etc. This sort of thing might just "go w/ the territory" of using dacron. But I wonder if there is anything I can do differently or better to minimize these things showing thru, so as to get more of a "showroom finish". I hesitate to use a wood filler for additional fairing of the newly made hull. Plus, it seems to me that using fairing compounds will inevitably fill in the small gaps between planks, which allow for some expansion without buckling. Would it be better to use a different filler on the dacron? More filler? Combination of the Ekofill and something else? Double-layer the cloth (doesn't seem practical)? . Any thoughts?
I'd like to work out for myself a likely approach before making my next "baby". Tks. very much!
Paul Buettner
Paul Buettner
