This will likely make most on this forum cringe, but I started on a trolling motor for my canoe. I haven't refinished the woodwork since I built it about 9 years ago so this is a good excuse to sand down the gunwales, etc. and revarnish them. While I am at it, I added new decks that allow easier mounting of the motor and an anchor system to the bow. I'll probably replace the thwarts too since one of them got chewed up a bit. The wiring for the motor is essentially finished, but I still need to run the cables for foot control of the motor and make the bracket (in place of the screwdriver in the photo) that allows you to raise the motor using the foot controls. The motor set up can be mounted and removed in minutes. I hope to wrap things up this weekend and take it for a test spin before a fishing tourney in two weeks.
Kurt
Kurt
