Mark Adams
all wood nut
Hi All,
I will be embarking on a bit of a new business venture here quite soon. With the advancement of technology, and after a random comment by Michael Grace, I formulated a plan on my way back from the Assembly;
On the way to me is a 3D printer as well as a 3D scanner. The printer I have coming has the capability of printing in a castable resin. This means that I will be able to go directly from a print, to casting in Bronze, Brass, or Aluminum. The printer is capable of a deposition rate of 25 microns. (0.000984252 of an inch) The scanner has a resolution of 100 microns, or 0.00393701 of an inch. Another HUGE plus is that shrink rate in the metal will be able to be added, thus resulting in a perfectly sized replacement part.
What does this mean to the wooden canoe fraternity? Well, it means this: I will have the ability to provide hardware that has been heretofore unavailable. (as long as there is one to scan) I will be able to have an "inventory" that exists solely in the digital realm, and cast on demand, or to provide that impossible to find hardware that you need 6 of, but you just have one. The castings can be provided rough, and in need of polishing, all the way to nickle plated, and ready to install.
The beauty of the scanner is that details, such as screw holes, will be accurately placed, and will match the original. With the resolution it is capable of, even the smallest detail will be captured. (the feathers on that elusive Morris flagstaff eagle...)
At this point, I have no idea what parts will cost. But, being able to hit "print" and walk away, to return to a castable part will eliminate a huge amount of time (and thus dollars) savings as compared to traditional lost wax casting.
I will be printing and casting both a Courting canoe canopy cleat, as well as a Willits style deck cleat as soon as I have the bugs worked out of the system. (and as soon as I receive both the hardware, and the parts to scan....)
What think you?
What think you?
