paddlingredrock
Hello, I am new here and have some questions about what some may call routine maintenance on a strip canoe.
In 1981, I built a strip canoe out of redwood with my father. He passed away in 2004, so the boat has a lot of sentimental value to me. From about 81 through 2002 I used the boat extensively and it has it's share of scratches and scrapes. During the time I was using it a lot i performed routine maintenance with sanding adding coats of spar varnish. Some of the scratches were deep and into the rosin, but not the cloth, so whenever I would sand these scratches would never come out as I never sanded too far into the rosin coat. I have one very major scratch that is down into the fiberglass cloth I believe. It would never clear up after applying varnish. It is about 1/2" to 3/4" width and about 5' long. It happened when I hit something metal in the bottom of a river. At any rate I am ready to make a full assult on the canoe and sand completely down and I guess you would call it a restoration and after I am finished I want the bottom of the boat to look near new if possible and get rid of all the deep scratches and especially that major one.
I am pretty sure we used 6 oz. cloth with two layers on the bottom. Used regular fiberglass rosin and hardner as we couldn't afford the new epoxy's on the market.
I think we put 3-5 layer strips on the bow and stern tip. Those areas are becoming cloudy, but I cannot tell if they are separating from the wood (I don't think they are separating from the wood, just becoming cloudy)
I did punture the boat once in very cold weather. The puncture went through the outside of the boat, through the wood and pushed the inner fiberglass layer off the wood. When it happened I patched the cloth on the outside (puncture) and it looks great. Really can't even tell where it happened. But on the inside where the cloth separated from the wood, I drilled a small hole and injected some rosin/hardner in the small area that was separated (about 6" long by 4" width) using a syringe. The process went well but the rosin only sealed the separation in the center 1/2 of the blemish, so now the cloth is still separated from the wood around the exterior of where it separated. This episode happened about 15 years ago.
Question 1: How would repair this major scrape in the bottom that is into the cloth and looks white?
Question 2: What would you recommend for repairing the inside the boat issue where the cloth has separated from the wood in a small area? Cut that small section of fiberglass out and replace with a patch over the entire damaged area, or just keep drilling multiple holes and trying to inject more rosin in the dead air space?
Question 3: What can I do with the bow and stern stems where the coating is yellowing/opaque?
I will probably have many more questions but this is a long enough post for now. I really would appreciate any of your comments and recommendations! Thank you very much.
